Un VEC en San Juan
Un VEC en San Juan
Alguien que no sabe muy bien lo que tiene está publicando para la venta un CJ 2A VEC, figurita complicada de conseguir.
El precio publicado es $130.000, lo que no sería caro para un 2A típico, mucho menos siendo un modelo poco habitual.
Como no todas son rosas, tiene el motor cambiado por un Conti 4 y hay que hacerle unas cuantas cosas. Pero en mi opinión personal vale la pena.
Entre ponerse a renegar para levantar un jeep más o menos común y hacer lo mismo con un VEC, no lo pensaría dos veces:
El jeep está en San Juan y el vendedor facilita el transporte porque tiene camión (flete no incluído, claro).
Sería bueno que lo rescatara alguien que entienda que es un modelo bastante especial y no caiga en manos de cualquiera que termine arrinándolo.-
Re: Un VEC en San Juan
Un hallazgo!
para los que no sabiamos que es un VEC (very early civilian)
https://www.thecj2apage.com/history.html
The serial numbers are located on the frame horn behind the front bumper. The first 100 or so were on the inside of the frame horn like the MB’s. Afterward the tag was mounted on the outside frame horn. At some point (after the VEC and VE series) the tag was moved to the firewall beside the air filter. There was also a body number. This number is on a small data plate and is located on the right side firewall by the air filter. At this point, I believe the serial number and body number should match. I have seen several CJ2A’s where this is the case. However, this is not written in stone. If you have an original CJ2A where the serial and body number does not match, I would like to hear from you. Early production engine serial numbers were located behind the oil filter, like the MB, and on later engines the number was on a boss above the water pump and in front of the head. The engine number and serial number will not match. Like the MB’s, the engine number got further and further apart as production continue. The very early 2A’s were close. CJ2A # 10115 has engine number 10125. Close but not the same.
Los números de serie se encuentran en la bocina del marco detrás del parachoques delantero. Los primeros 100 o menos estaban en el interior de la bocina de marco como los de MB. Después, la etiqueta se montó en la bocina del marco exterior. En algún momento (después de las series VEC y VE), la etiqueta se movió al firewall al lado del filtro de aire. También había un número de cuerpo. Este número se encuentra en una pequeña base de datos y se encuentra en el lado derecho del firewall, junto al filtro de aire. En este punto, creo que el número de serie y el número de cuerpo deben coincidir. He visto varios CJ2A donde este es el caso. Sin embargo, esto no está escrito en piedra. Si tiene un CJ2A original en el que no me gusta, me gustaría saber de usted. Los primeros números de serie del motor de producción estaban ubicados detrás del filtro de aceite, como el MB, y en la parte posterior de la cabeza. El número de motor y el número de serie no coincidirán. Al igual que el MB, la producción continúa. Los primeros 2A estaban cerca. CJ2A # 10115 tiene el número de motor 10125. Cierre pero no igual.
Mira vos, hoy busque y salió ese, si ven alguna foto subanla y si Miguel puede borrar las que yo subí estaría bueno así no generamos confusión.
Alejandro, tiene razón Ramón. Ese como mucho y a juzgar por la parrilla, puede ser un Early pero no un VEC.
Este es un VEC, aunque el color (muy lindo, eso sí) no sea ni parecido a los colores originales:
Hay muchos a los que se puede denominar VEC de acuerdo a los detalles de MB que mantenga, pero lo notable de ese que apareció en San Juan es que tiene las "arandelas" del frente del parabrisas cuadradas, que es un detalle que sólo apareció en algunos muy pocos de los primeros.
Lo llamativo es que el dueño comenta que en los papeles figura como 1946, aunque supongo que esa debe ser la fecha en que se patentó en el país.
Con ese parabrisas es 1945 de acá a la China, ida y vuelta en chancletas
Otro detalle es el agujero para que pase la barra de dirección ovalado, para que pasara la barra de la palanca de cambios al volante de los primeros modelos.
Vaya a saber como se coló en alguna de las primeras partidas que entraron al país
Detalle de la arandela cuadrada:
Max
CJ2A - 1947 - 110861
unaMax escribió: ↑Vie Jul 05, 2019 8:24 pmhttp://www.ewillys.com/2007/03/14/draft-article/
es mi sueño uno de estos con la palance en arriba.
Estimados, les cuento que lo tengo señado al VEC, viendo con un gestor porque los papeles no están 100% en regla...
El motor no esta dado de alta en el jeep, por lo que hay que verificar, no tiene chapitas de la carrocería, el dueño actual nunca se lo transfirió, etc,etc. Despues les cuento como me fue.
Yo hace tiempo estaba buscando un CJ2-a para militarizar pero a este le tendría mucho mas respeto. Si lo "militarizo" sería solamente un cambio en el color, sin tocar nada de chapa ni colgar rueda atras ni nada raro. Así si en unos años cambio de opinión es solo un tema de pintura.
Si tuviese el motor original ahi si no la dudaría e iría por un 100% original
Bieeen! Una alegría que no se pierda!
Ojalá se te de y puedas recuperarlo. Realmente es un ejemplar que vale la pena: dudo que haya otro en el país.
Cada uno hace con lo suyo lo que quiere, pero personalmente no dudaría un segundo en recuperarlo a su condición original de civil.
Lástima lo del motor, pero mirando la mitad del vaso lleno, tené en cuenta que siendo un VEC le va tanto un motor de CJ como un cadenero de MB.
Cuando los iban armando les ponían lo que tenían a mano, y muchos salieron con motor de guerrerito.
O sea, cualquier colectivo lo deja bien.
Tenenos al tanto de las novedades y preguntá lo que necesites, que lo que no sepamos lo averiguamos: el amigo Oddo de USA tiene uno impecable, y lo hizo todo él, asique no va a tener ningún problema en facilitarte toda la información que te haga falta.-
felicitaciones!!! ojala se de todo como lo deseas guilarrea-
En Rosario Jeep hay un forista que está por cambiar un go devil por un diesel cummins,en su Jeep, por ahí lo vende
http://www.rosariojeep.com.ar/foro/view ... =2&t=27128alejandromp71 escribió: ↑Jue Jul 18, 2019 3:12 pmEn Rosario Jeep hay un forista que está por cambiar un go devil por un diesel cummins,en su Jeep, por ahí lo vende
hola se lo ve bien Alejandro pero esta lejos... hay que traerlo de Peru no?
M 38 1951 o 1952?
ika 1969
